re:tranny to c-m issues
Are you sure your eng is sitting right where it should be? 1" isnt that much really.If it truly is in right then It seems that for some reason the vehicles eng that you got the cross member from is, was sitting 1" forward of what your motor is. Could be a 1/2 yr model change happening to you that occasionaly happens. Check if there were any changes in motor mounts on that year. I recently had similar problems only to find my exaust mount bracket location had moved just enough to keep the motor from sliding all the way in. Made it W/ 1/2" clearance and some persuasion. Also now I have an extra crossmember or two. good luck.
KemoChevy
This is a complete swap out deal there is some history here with the car and why I'm doing this madness. good call on the motor mounts, the motor mounts are from Energy Suspension and the set I have on the car are the short and wide which are incorrect for my car model year so they sent me the 2 5/8" wide ones that are tall, these should work. On the wide and short mount I have on the car I noticed a 5/8" gap on both mounts the one on the drivers side the gap is closer to the firewall on the passenger side the gap is to the front of the car, weird. I just received the new mounts from Energy Suspension today and plan on installing them to see what happen. As for the model year early camaro like mine didn't come with a TH400 tranny they where for the impalas or BB cars, but the 67 firebird with the 400 engine did come with the TH400 tranny. I spoke with Jim who owns Heartbeatcity.com who in turn spoke to Rick who did owns Ricks First Generation and they informed me through Jim that in order to solve this issue I would need to find a cross member from a 67 fire bird with the 400 combo. I found out that finding a needle in a hay stack would probably take less time. Thanks for the input Kemochevy you are on the money and I appreciate the input a ton. I will keep you posted on the outcome.
crossmember blues
hey 67 camaro, have you thought of using a nova crossmember for your application, they are sub frame cars as well and some of them came with the th400 setup factory and would probably be easier to locate than b.o.p. stuff would, if im not mistaken the nova crossmember is the same width as is the rearend. hope this info may help you.
The only '68-'74 Novas with T-400s were big-block cars, and as such have the engine and trans offset to the right. Small-blocks got the T-350 if they got a 3-speed auto at all.
The holes in the Chevy T-400 unit can be modified to move the mounting point a little to the left for use with SBC motor mounts, if you don't mind grinding on it a bit. Any idea how to tell the Pontiac crossmember from a Chevy? Last edited by jimfulco; 01-13-2008 at 08:02 PM. |
I'm really not being a smart***, but I have recently installed a engine tranny combo for a customer who had the engine and tranny mounts in place, and had the tranny crossmember bolted in backwards!
| Vibration issue driving me insane | Blue67Camaro | Transmission - Rearend | 13 | 05-24-2007 06:53 AM |
| 57 Chevy auto trans cross member | pikalpha | Transmission - Rearend | 7 | 12-09-2005 01:02 PM |
| Introducing Myself : ) | Aboveknee | Hotrodders' Lounge | 20 | 01-19-2004 02:39 PM |
| 84 C10 TH350 Cross member to a 700r4 mount??????? | juveteach | Transmission - Rearend | 3 | 06-13-2003 10:54 AM |
| Tranny line and rear cross member question. | Bo_Jangles | Transmission - Rearend | 3 | 03-08-2002 08:18 AM |
