Tranny and engine swap questions...."1990 caprice classic"th400 vs 67' muncie 4 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2007, 11:03 PM
i just got a caprice with a 305, the engine is a tbi 305vortec and a T.H. 400 transmission. Meanwhile i noticed that i`m gonna have to buy a combination universal jointi was also wondering, is there anywhere that i could get dimensions of either tranny wondering if i couldn`t usemy old driveshaft or will i have to use the one from the caprice? any pointers are welcome. thnx.
Old 02-09-2007, 11:14 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The Vortec engines weren't out in 1990. It probably has centerbolt valve covers but it probably doesn't have Vortec heads. Also, a quick search found that those cars had 200-4Rs or 4L60 transmissions, no T400s. Is there an option list somewhere in the car that gives a transmission code? Is the car a Police Package?
What vehicle are you thinking about swapping the parts into? You didn't mention that part...
Old 02-09-2007, 11:25 PM
305 Tbi
it is an out of service taxi. i`m taking the ole inline 6 out and wiring up this tbi 305. it runs better than the inline six.
that`s for sure. i have a couple things on the board that i could do.
A. 305 with 200-4 auto.
B.305 with muncie 4 speed
Old 02-10-2007, 08:49 PM
http://tciauto.com/Products/TechInfo/trans_dims.asp has dimensions for automatics.
Old 02-10-2007, 09:27 PM
305 swap into a '74 chevy truck
i`ve started to take loose all of the under dash wiring.this car has a *sim* system . i have no clue about what this sim system does. and seeing as how this is the place to come for advise. What is a Sim system in a 1990 chevy caprice classic. and what all of the computer system do i need for the transmission. ? there are 2 out board access modules , one is located under the steering column This is the (ecm)engine control module.. The other one is a larger module no clue what it is for yet havn`t traced the wires . I`m guessing it is the spark control module; it`s located in the frnt. passenger foot well.
i was working in a typewriter style taking it all loose. this is when i noticed the location where the sim is located infront of the driver windshield. any know exactly what components i need to hook this up . Or has done this.?
my inline six has seen better days
and i wanna try a 305. i may upgrade to a 350 with the TBI.
I`ve done some reasearch and all i would have to change out would be the injectors aftermarket fuel pressure regulator , 350 knock sensor. . but for now the 305 with an automatic that`s a plus also. i`ve been running into a lot of stop and go traffic. Any help or even ideas are welcome.
Old 02-10-2007, 09:28 PM
Spell corection
SIR not sim sorry for the confusion,
Questions about an engine and tranny that set for years? RAW Engine 7 04-08-2005 10:32 PM
235 Engine / Powerglide to 3 speed swap New2theart Engine 2 07-16-2002 06:22 PM
LS1 engine with 6 speed tranny. nvivion Engine 1 05-26-2002 07:44 AM
