tranny fluid ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 06:59 AM
bodie filyaw's Avatar
GMC TRUCKS
tranny fluid ?
Been told that type-f tranny fluid is better for my new duel feed th350 and will also give it a firmer shift.Is this true are is it hog wash?
Old 02-01-2011, 07:02 AM
BEC's Avatar
BEC BEC is offline
29ster
Last journal entry: Rear suspension
I recommend only what the OE recommends. Don't mess with the universal fluids or any other modifiers.
Old 02-01-2011, 01:06 PM
SSedan64's Avatar
Type-F will give slightly firmer shift feel. Your choice, Dex III, Type-F either will work fine. Many like the new Synthetics but they're pricey.
Old 02-01-2011, 01:10 PM
Dexron VI replaces the old Dexron III. It is far superior to the old Dexron III!
Old 02-01-2011, 01:14 PM
SSedan64's Avatar
I agree, it's not cheap tho'. Dex VI is Synthetic.
Old 02-01-2011, 03:04 PM
Dexron VI? Don't you mean Dexron IV?
Even that has been replaced with a Dexron/Mercon formula
Old 02-01-2011, 03:25 PM
GM went from Dexron III to the Dexron VI designation. Dexron VI is the latest Dexron fluid and replaces ALL Dexron fluid recommended for use in GM Automatic Transmissions.
Tractor fluid instead of regular tranny fluid! Studebaker Transmission - Rearend 24 10-17-2012 07:44 AM
Have Old Unopened Tranny Fluid...OK or NOT? bartamos Transmission - Rearend 2 10-04-2007 02:03 PM
how much tranny fluid badriand Transmission - Rearend 4 06-05-2007 09:06 PM
'84 XJ leakin' Tranny Fluid Jeeper426 Transmission - Rearend 5 03-20-2006 09:03 PM
Tranny fluid question McCutlass Transmission - Rearend 3 04-14-2004 08:52 PM
