tranny good except one strange issue
I posted here a couple days ago but misrepresented the symptoms so I am starting over.
1993 Buick Century 3.3l 4-speed automatic does this: - while moving at any speed it shifts and runs fine - while at stoplight, if you were just driving at 10mph or more, shifts into a false neutral while stopped and you have to manually shift it to neutral and then back into drive to get it to engage - while at stoplight, if you were formerly driving at 5mph, stays in gear and takes off like normal upon acceleration - when gear shifter is in lowest (1st) gear, runs fine regardless of how many times you stop and start. Never falls out of gear To summarize, it seems the car is unable to downshift from 2nd to 1st and when a 2nd-to-1st downshift is called for, it falls into neutral. |
High mileage tranny? Original tranny in the car ( If you know)?? Does the tranny operate the same cold & hot?? A multitude of items can cause your neutral situation as described. worn seals ,hard internal seals , short lip seals on the pistons input drum, sprag clutch not holding , input clutch pack worn out, pump is worn out = low pressure the tranny will drop out of gear. In manual 1 gear , there are more items applied , so the tranny has more holding power. the flush job probably flushed out some debris that helped the tranny function.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Trans is a 4t60 Quote:
Thanks! |
http://www.hotrodders.com/forum/tranny-good-except-one-strange-issue-118449.html
Hello from the great white north . Don't know if you still frequent this board or not but here goes. We have a 93 olds ciera 3.3 with 4 speed auto thats doing the same thing your car was, we had put another tranny in it so i'm thinking its maybe an adjustment thing . We put all new filter & oil into it so the guts are good . I was wondering if the tranny gave up the ghost or worked ok driving it while it worked this way . Later bake
m/w ; please read dates on threads
The member that posted the original thread question has not logged in since 2008.
| The Following User Says Thank You to Crosley For This Useful Post: | ||
m/w (01-14-2013) | ||
| whats a good manual tranny? | jesse01 | Transmission - Rearend | 8 | 07-24-2006 10:28 AM |
| Is this normal? High mileage tranny | Jmark | Transmission - Rearend | 8 | 10-17-2004 09:40 AM |
| Tranny pan bolts and tranny pan ufo | entropy | Transmission - Rearend | 6 | 10-06-2004 10:26 PM |
| camaro z 28 tranny shifting problems | chevcamz28newbie | Transmission - Rearend | 8 | 07-22-2003 07:43 PM |
| 70 roadrunner engine and tranny | Oddi | Engine | 1 | 11-23-2001 12:38 PM |
