Tranny has a grimlin - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-23-2014, 10:13 PM
m/w m/w is offline
Z 55 Camaro
Location: Guernsey Sk Canada the greatest country in the world
I have had the codes erased after each time i have worked on the truck with a tech 2 scanner .I've erased them twice and as soon as i fire the engine the check engine light comes on and its showing torque convertor solenoid ,1to2 shift solenoid,and 2to 3 shift solenoid not working and its gone into default as you described . Ok thank you ever so much for all the info. Just a thought could one of the solenoids be faulty and in turn for the lack of a better word cause the other solenoids to register as not working ? Maybe a day or to to get at it cause re bar and cement is coming
  #17 (permalink)
Old 07-23-2014, 10:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if you have 5.56 volts at the transmission connector for pink wire, that will not function correctly. That needs attention. It must have full system voltage 12.6+ at the solenoids
  #18 (permalink)
Old 07-24-2014, 06:24 AM
Banned
it's a common issue.. the pink wire, check it.. it's fed from the ign switch..
was told by a g.m. tech this when dads was doing this..
  #19 (permalink)
Old 07-24-2014, 08:54 AM
It would also be very odd to have 3 different solenoids fail simultaneously. Not likely the case. The only way I could see 3 solenoids having an issue at the same time is if the internal wiring harness is bad. More likely you have a power supply problem. Test the power wire as described above.
  #20 (permalink)
Old 07-24-2014, 12:35 PM
m/w m/w is offline
Z 55 Camaro
hats my thought exactly i will get on that to day and get back to you , The basement supplies are coming so may take a day or so. As the young apprentices say you guys rock
  #21 (permalink)
Old 07-24-2014, 11:20 PM
m/w m/w is offline
Z 55 Camaro
Just finished one hell of a wind/ thunderstorm ,the wife and i were out moving cars from under the trees around the driveway . I jumped in the tahoe (same one with the gremlin) and the tranny, gauges worked perfect go figure so now i know its 200% electrical and thats great , have a good sleep and beware the hail.
  #22 (permalink)
Old 07-28-2014, 06:07 PM
m/w m/w is offline
Z 55 Camaro
OK more little tidbits I was asked by tranny guy from the city if the little red light on the shifter went out ,yes said i it does once in awhile then stay on each time you start the tahoe or you can turn it off and the next time it will stay off but sometimes it'll stay on when you manually go through all gears or it picks a gear and goes out .Now he figues the selector module on tranny is on the way out . So just to throw another kick into the equation i squired some wd-40 into the ignition switch and the selector light stayed on , the gauges worked and then after 2to 3 starts it acts the same . Main harness tests same voltage as battery so current is getting there ok . Where i got the 5.56 reading was on the drivers side of the tranny on the gear shift selector module . I sorry for the screw up before mis information is a bad thing .Thanks to all who have taken the time to get me info , those wiring diagrams were priceless . Well back to chasing wiring . Later bake
  #23 (permalink)
Old 07-28-2014, 06:51 PM
m/w m/w is offline
Z 55 Camaro
Damn it forgot to mention that we used the tech 2 scan tool and tested the shift solenoids and they all worked,along with the converter lockup .I lay on the ground while my nephew ran the scanner and i could hear each one click .FYI boy you guys are going to be sick of me by the time this is finished .Later bake
  #24 (permalink)
Old 09-07-2014, 02:39 PM
m/w m/w is offline
Z 55 Camaro
Well between catching the plague and doing house renos finally got the electronic gear select on the tranny and took it out for 5or6 mile run and it worked perfect ,i will take it out for a longer run tonight and hopefully it will keep playing nice . Ican't remember the name of the piece i replaced but it bolts on to the outside of tranny and has 2 wiring outlets on it . Once again many thanks to all the members for there help and advice . Later Bake
  #25 (permalink)
Old 09-17-2014, 11:54 AM
m/w m/w is offline
Z 55 Camaro
Hopefully this is the final post on this tranny thing . As previously stated the tranny worked great for 2 days and then it started acting up again so to hell with it and off to the garage . The mech traced the harness all the way back to the ignition switch assembly and the wiring harness there was poached so in went a new one and the tahoe runs like a dream so once again thanks to all that offered help and have a great fall and hope you didn't get snow like calgary did a couple days ago .Later Bake
700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ? limp'n-gmc Transmission - Rearend 6 02-15-2011 08:58 PM
What Tranny? jsarnold Transmission - Rearend 37 01-12-2010 05:42 PM
what tranny do i have 94chevys10_zr2 Transmission - Rearend 8 07-15-2009 11:11 PM
Tranny pan bolts and tranny pan ufo entropy Transmission - Rearend 6 10-06-2004 11:26 PM
What tranny would be best? BillyBob1950 Transmission - Rearend 1 12-07-2002 02:55 AM
