Tranny has no forward or reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2006, 12:05 PM
Hi,
I would be most grateful if you would give me some advice on the following.
6 months after the transmission fluid change by an indy, the below symptoms developed. After a mile to a mile and a half of low speed driving, my 2001 saab 95se with 67k on it, lost both forward and reverse gears. The car wouldn’t move while engine revved. Check engine and transmission warning lights were on. Autozone found code #P0730.Talked to the same indy and then the dealer, both said that I need a new tranny. Both didn’t open the tranny for inspection to find out the cause of the problems. I then used a bottle of “Sea Foam” and changed the fluid. It was dirty These particles are as small as you would find in metallic paint. However, the driving mileage increased from 1 mile to about 10. I made second fluid change 2 days later and it was dirty and there were small amount of metal presented in drain pan. These metal particles are as small as those found in metallic paint on car surface.
Do I really need a new tranny or something minor? Note that the indy who did the fluid exchange has put in Dexron 2 instead of Saab specify Dexron 3. How do I know? It's handwritten on the receipt.
Any advice would be much appreciated. Many thanks
jb
jb
Old 04-14-2006, 03:00 PM
scrot's Avatar
Let's hear about some background of the car.
Did you buy it new?
How did you get it?
Who has been doing the maintenance?
Old 04-14-2006, 04:15 PM
Did you buy it new?
How did you get it?
I bought it a year and a half ago with 47k on it from Ebay. The car was mechanically excellent, as evidented in the next 20K of driving. It has no tranny problems whatsoever. The car was serviced by the dealer prior to my purchase and I have all record to show for it. I went to the indy for 60K service and 7k miles later, I got the tranny problem.
Old 04-15-2006, 04:59 AM
65Stanger's Avatar
Check the water, check the oil
Could be a HUGE deal. When you put the shifter into forward or reverse, does it shift into drive or reverse? (can you feel it shift into gear?) Check your shifter cable. It will look like a plastic boot on a round pin thing, has a cable that goes up into the car. It's on the driver's side. Is it broken? Make sure that you have ENOUGH fluid (and not too much) When you drained it, you put in Dex III right? When checking tranny fluid, make sure that the car is in park and running. DO NOT OVERFILL. =) There are a number of things. If it's a broken shifter cable, that's a problem. FWD/RWD? Jack up the car so that the tires that would move the car are off the ground, put the parking brake on, and shift it manually down at the transmission into Drive/Reverse. MAKE SURE THE TIRES ARE OFF THE GROUND OR THE CAR WILL START ROLLING. If the shifter cable's broken, and this puts it in gear (when you give it gas the tires spin) take it in to a tranny shop to have the cable replaced, unless you feel up to doing it yourself. If you have a lift accessible to you, USE IT INSTEAD OF JACKS. It's a test that will tell you for sure if it's an internal problem or not. The boot usually just pops off of the pin on the shifter plate. You'll see what I'm talking about when you look at it. Let us know how it goes... hope I've helped! Just how I'd do it.
*Edit*
Little research, here ya go.
"The remedy/solution for the MIL Error Code (P0700, P0730, P0715) from a Technician's Book was to replace the "Shift Control Solenoid Assembly", then if the problem persist, replace the "Linear Solenoid"."
http://www.autofan.com/forum_reply.a...8&level=3&all=
Old 04-15-2006, 02:52 PM
Jmark's Avatar
That still doesn't account for the metal in the fluid. Me thinks something went way bad inside.
86 Dodge 4x4 727 tranny no reverse after loud metallic pop sound? mike 96 ws6 Transmission - Rearend 4 03-14-2006 12:43 PM
How can you tell if its a forward or reverse valvebody? 84Z Transmission - Rearend 5 11-24-2005 12:50 AM
TH350 roll forward in reverse? montea Transmission - Rearend 5 07-05-2004 02:11 AM
5 speed tranny with forward shifter? Warm_Spit Transmission - Rearend 2 08-13-2003 09:09 AM
GM T-5 tranny.....no reverse or fifth gear??? chevyelc81 Transmission - Rearend 2 01-07-2003 06:29 PM
