tranny id help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2002, 09:31 PM
Post tranny id help
i've got a 60 dodge 4x4 with a factory warner transmission. its a four in the floor, im guessing its got a granny low gear but im not sure on that. my question is does anyone know what type of tranny this is and what it might sell for? if needed i can crawl under the truck and scrape some gunk off to find the serial numbers.
Old 09-14-2002, 01:49 PM
woodz428's Avatar
Troll Hunter
Post
Some kind of number would help for accurate I.D., and it's value is probably only for some one with a similar drivetrain. Early 4x's of different makes used a lot of commaon components, so when you get the numbers it may fit a variety of 4 wheel drive trucks.
Old 09-14-2002, 11:41 PM
Post
ok i went outside today, and right as i was getting ready to climb under the truck with some WD40 and a scraper, i decided to check the vin tag in the doorjamb. it was right there in black and white *slaps forehead* its a warner T85E. anybody know anything about these things?
Old 09-15-2002, 03:23 AM
hotrodit's Avatar
Talking
Probably weighs a ton!!
Old 09-15-2002, 10:14 PM
Post
ttt
