Tranny identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2004, 06:13 PM
New Member
I picked up this tranny at a garage sale for $5.00 today. It appears to be in good shape inside. I am having trouble identifying it. I believe it is a a-833 mopar, but it does not look exactly like any of the pic or diagrams i have found on the Internet. It also has an OD 4th gear.
Any help would be appreciated, as well as it's value.......
Old 06-05-2004, 06:14 PM
New Member
nuther pic
2 of 3
Old 06-05-2004, 06:16 PM
New Member
last pic
3 of 3
Old 06-08-2004, 09:09 PM
New Member
No help on this. BTW, the case is aluminum......
Old 06-09-2004, 06:35 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
All I could find on this is it matches a New Process transmission, but I couldn't find out the model number.
Old 06-09-2004, 08:59 AM
NP-440??? Mid 80's Chevy truck??? Only ever seen one, and it had the NP logo on the top of the case.
The A-833 was built by New Process. From what I gather, nearly the same guts in both Dodge and Chevy versions.
1 1/8" 10 spline input shaft for the Chevy trans.
Gear ratios where poor. Had a real wide spread between 1st and 2nd. Something like, 3.09 ,1.67, 1.00, .73. Dan
Old 06-09-2004, 10:08 AM
New Member
It does have the NP cast into the right side.... NM
0
