Tranny jack - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2004, 12:44 PM
Last journal entry: Some pics
Tranny jack
Ok, do you have a transmission jack and how do you like yours if you do?
Also I think I have seen little brackets or attachements you could add to your floor jack. Any opinions on those? Maybe I could weld something up that would fit my floor jack using some scrap I have or maybe some fresh angle iron. I have some square tubing but don't have any angle iron sitting around. And what flat stuff I do have would not be enough. Should be an easy enough project if it would work well.
Old 09-12-2004, 01:21 AM
I have one like this: http://www.harborfreight.com/cpi/cta...emnumber=39178
I've used it twice, and the only problems I have had (aside from forgetting to grease the threads on the screw) were:
1. It raises the top of a Turbo 350 to ~27" off the ground, & I couldn't get the truck high enough to roll the whole mess under the frame rails, so I had to put the tranny on the jack after both were slid underneath. I now have taller stands & a bigger floor jack.
2. It tends to lean to the side a bit when it's extended, so I had to put a piece of 3/8" plywood under one side to get the trans level enough to align the dowels. This was also fun underneath the truck. My carport has a slight slope for drainage, & this might have been a factor.
3. Don't have too much faith in that strap. I thought mine was tight, but it still slid to the side far enough that I thought it was going to take a dive. This was probably my fault, but be careful anyway.
I think HF has those on sale right now for $10 or $20 off.
Old 09-14-2004, 08:38 AM
bigbird's Avatar
Last journal entry: Blasting Cabinet
I've got the same model and that strap isn't worth ****. My 400 turbo slides all over the place.
Old 09-14-2004, 11:58 AM
cboy's Avatar
Last journal entry: Finished
Stop squirting your Miller High Life on it.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
