warn tranny and motor mounts can cause this. The tranny and engine is shifting causing the clunk.
Open your hood and watch the engine while someone shifts it for you. If you have more than a 1/4 inch of movement then you should probably check the mounts. Good luck Jake |
How high is your idle speed set at?
What about the condition of your "U" joints? Either of these can also cause that clunk.
Ontario Rodders |
| 2004R tranny | sotxpanrider | Transmission - Rearend | 0 | 05-20-2006 08:49 PM |
| Tranny update/Torque converter question | RObs71Nova | Transmission - Rearend | 5 | 12-16-2004 09:37 AM |
| Pulling motor/ tranny 66 C10 | 66thom | Engine | 6 | 10-27-2003 09:46 AM |
| Tranny fluid heating up engine??? | black66 | Engine | 1 | 07-13-2003 09:18 PM |
| 88 AOD tranny problems | rflud | Transmission - Rearend | 9 | 02-17-2003 04:53 PM |
