Tranny Line - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-02-2004, 10:46 AM
tranny line repairs
The replies you are getting are great,
1st blow out lines and cooler , make sure of no restrictions
if rubber line is to be used flare ends, install hose with silcone hose claps, reason being they clamp on a band inside and give a complete seal,
replacing steel line with compression fittings works great if the area where its leaking is easy to get to. do this,
best way is to do it right the first time and replace the line, its a lot cleaner , and dont forget to tie them up and stop the vibration
like install split fuel line hose around the lines and tie them up but do it in a clean fashion.
it's your ride how proud of it are you? no body likes a car that isn't house broke.
