tranny lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2009, 10:04 PM
86camaroirocz's Avatar
tranny lines
so i have a 700r4 and i hooking up a tranny cooler and i dont know which line from the transmission goes where... i want to make sure it is right cause this is a new tranny.....
Old 04-17-2009, 02:06 AM
malc's Avatar
Living At The Speed Of Life
Try posting in "Transmission-Rearend"
Old 04-17-2009, 05:22 AM
I too wonder the same question.....I always thought a tranny cooler is just a tube with fins to disapate temperature.....so how could a plain tube be directional? Same with cooling thru radiator(as I am doing)? I do know that the Bottom line on the tranny is the OUT line and the Top line is the Return Line......so if a Cooler has directional info ; there you go.....but on a radiator where the trans cooling connections are at the bottom; I have no clue.
Old 04-17-2009, 06:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 86camaroirocz
700r4- which line from the transmission goes where...
700R4/4L60/4L60E/4L65E
Fitting Location......Thread Size.......Flow Direction
Upper......................¼" Pipe............Return/in
Lower......................¼" Pipe............Cooler feed/out
Plumb the auxiliary cooler after the fluid has passed through the radiator cooler first.
Not all common GM trannys use the bottom as the cooler feed, the TH200C Metric and 2004R are opposite this.
Old 04-17-2009, 04:45 PM
the tranny cooler i have is aftermarket not factory it also dont say in or out on still need to know what is the in and out on the tranny cooler thanks....
Old 04-17-2009, 09:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
cobalt327 answered your question quite well.
It actually does not matter how the lines are hooked up since there should be no check valves in this cooler system on the 700r4 trans.
the cooler system is under pressure , make the proper rated hose is used.
Old 04-18-2009, 08:36 AM
ok that helps alot someone told me it didnt matter but i just wanted to make sure thanks
Old 04-19-2009, 05:58 PM
fast68's Avatar
likes chevy trucks & boobies
i always put mine how i always have seen them, and that is bottom to bottom and top to top
Th350 what tranny lines? scapegoat Transmission - Rearend 3 03-16-2008 08:01 PM
S-10 oil lines NORM47 Engine 1 04-22-2006 07:19 PM
Kerry and jobs overseas... lluciano77 Hotrodders' Lounge 9 12-25-2004 08:59 PM
help with tranny munbers notmrgoodwrench Transmission - Rearend 2 01-23-2004 09:59 PM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
