Tranny pan bolts and tranny pan ufo - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2004, 07:41 PM
As the saying goes...
"No good deed goes unpunished"
I decided to change my tranny fluid tonight. I had order a deep tranny pan to replace the stock model (460 C6 Transmission)
Problem number 1
- Some of the bolts came out real easy. 5 did not, and the heads snapped off.
I guess I have two choices, easy out, or heli coil. Reccomendations?
Problem 2
- When I got the tranny pan off, this was sitting in the bottom of it:
Any clues? Does it belong there? Doesn't look like it goes anywhere.
It is about 1.5 inches in length.
Thanks!
Old 10-06-2004, 07:48 PM
suck, squeeze, bang, blow
Last journal entry: finally reeled it in
Don't know what that is. I would try an easy out before Heli-coil. Then I would drill and tap if that didn't work. Westward makes a really good set of easy outs. I have a set of KD's too, they break if you just look at them funny.
Old 10-06-2004, 07:53 PM
Found the answer to the wierd platic part. Google is my firend!
http://autorepair.about.com/cs/faqs/l/bl602f.htm
Old 10-06-2004, 08:15 PM
Crosley's Avatar
Wiki Edits: 1659
Plastic plug ford uses on assembly line.... it does nothing inside the pan
Old 10-06-2004, 09:01 PM
Grumpy
Re: Tranny pan bolts and tranny pan ufo
Problem number 1
Problem 2
Thanks!
Hey, I know you, you came into the advance store I work at last week... at least I think it's you, cant be to many others out there with that same problem at the same time... could there?
Old 10-06-2004, 09:17 PM
Nah, it just happened tonite!
Old 10-06-2004, 10:26 PM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
left handed drill bits might make the job easier.
