Tranny plug
Anyone have a solution to getting a rusted stuck, rounded off, sq head plug out of an Aluminum Muncie housing?
I'll bet you already tried penetrating oil and vise grips.
Try warming up the aluminum with a torch. the case will expand some and maybe give up the plug. I never have good luck with drilling hard plugs out of soft materials, the drill always seems to get into the stuff I want to save. Try welding a big nut to it. Put the nut on the top and fill the center with weld. this will give you something to grab and the heat will help bust the plug loose. If it is stuck now you will probably have to retap the hole some. hope this helps, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
I broke several 8 Point sockets with a long breaker bar, major league pipe wrench finally rounded it. It laughed a vise grips.
Tried some heat, maybe not enough though. The welded nut idea sounds promising. Nice big heavy hex nut where I can get some leverage. Between that and heat... maybe? Work it back and forth. Thanks Brass plug next time around? Teflon tape or anti-seize? |
Is there any of the plug sticking out of the case? If so I have had good luck using an air hammer and dull chisel bit to get it to turn. Just don't take a big bite so it won't just rip a corner of the plug off. Be careful of heating the aluminum case, I have seen too many melted aluminum parts from just that.
Steve |
| clanking tranny | lovoiboy | Transmission - Rearend | 2 | 06-10-2004 01:15 PM |
| 95 sonoma tranny problem | 383MontecarloSS | Transmission - Rearend | 0 | 05-29-2004 01:25 PM |
| my tranny wont shift hard even with shift kit | notmrgoodwrench | Transmission - Rearend | 4 | 08-12-2003 06:10 PM |
| Tranny fluid heating up engine??? | black66 | Engine | 1 | 07-13-2003 09:18 PM |
| 70 roadrunner engine and tranny | Oddi | Engine | 1 | 11-23-2001 12:38 PM |
