Tranny problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2009, 04:15 PM
chewyscool's Avatar
Big Block 454
Tranny problem?
I have noticed the last 2 times I have started my car and put it in reverse it Hardly pulls, when before you need not give it a gas and you could back right up. Also in drive same condition. If I do give it some gas it will move as it used to. I have a 700r4 and a 2400 stall. Shows good on fluid when warm but the stick is hard to read though. This has been running only 500 miles so far. Any thoughts.
Old 08-24-2009, 04:25 PM
SSedan64's Avatar
TV cable connected and adjusted correctly?? You're not comparing before with stock converter and after with 2400 stall converter, are you??
Low & Reverse have higher pressure than other gears so something is not right.
Old 08-24-2009, 05:08 PM
chewyscool's Avatar
Big Block 454
No since 0 miles to present, tv cable has not moved for its working point.
Old 08-24-2009, 05:19 PM
SSedan64's Avatar
You need to hook up a pressure gauge. Port just above the shift lever shaft. Pressure Info at bottom of this page applies to the 700R4 also. > http://www.extremeautomatics.com/techinfo.html
TCI's pressure #'s >> http://www.tciauto.com/Products/Tech...e.asp#TH200700
Old 08-24-2009, 05:43 PM
chewyscool's Avatar
Big Block 454
Thanks for the info, I'll give it a shot and see what I come up with.
1995 4T60E tranny problem sonsmech Transmission - Rearend 4 05-07-2008 06:48 PM
lockup and speed-o-mat problem stopel Transmission - Rearend 4 03-25-2008 07:33 PM
97'C1500 4L60e tranny problem fiolater Transmission - Rearend 3 03-23-2008 07:27 AM
Ford Probe Tranny Problem lala Transmission - Rearend 0 02-26-2006 11:59 PM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
