Tranny problems in 2000 Grand Am - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2008, 04:08 PM
My girlfriends 2000 Grand Am has been doing some really weird stuff. It has a 3.4 six cylinder with a 147000 miles. Lately when driving down the road when going up hills it shutters and the service engine soon light flashes on and off. When you give more thottle it gets worse and when you let off it stops. Today after driving 30 or so miles I parked and went into the gas station when I got in to go I put it in drive and all it did was rev to 2500 to 3000 grand and gradually started to pull. I shifted it in and out of park to drive several times and it finally acted normal again. I am going to change the filter and fluid tonight to see if this will solve the problem. Does any one have any ideas what could be causing this Thank you.
Old 05-29-2008, 04:39 PM
T-bucket23's Avatar
Wiki Edits: 26
Sounds more like ignition wires than a tranny issue. I dont think you can get a flashing CEl light from a tranny issue. I would pull the plugs and if at all questionable, change them and the wires. If you have access to a code scanner I will bet you have missfire codes. The flashing CEL means you are possibly damaging the cat. I would bet on bad wires. They are fairly cheap and easy to change. The back ones are a little tough, make sure the engine is cold or you will burn the heck out of your arms
CHet
Old 05-29-2008, 04:42 PM
T-bucket23's Avatar
Wiki Edits: 26
If there is an Autozone or something like that in your area they can scan it for codes for you. Make sure you buy quality wires or you will be doing it again !!.
If you dont fix it you will eventually destroy the cat with the raw fuel.
Old 05-29-2008, 04:52 PM
Pontiac problems
The issue with needing a tune up is probably correct but the tranny is really slipping bad. I thought I should tell you that the engine light was flashing so you guys knew the whole story. When I put it in gear it just revs and gradually starts to grab. If I cycle it back and forth through the gears I can get it to act normal. I know its difficult to diagnose when there are more issues at hand but this in my opinion is one of the best sites on the net. You guys are the best. I will take a look at the plugs and wires as well. Thank you.
Old 05-29-2008, 04:55 PM
T-bucket23's Avatar
Wiki Edits: 26
Try dumping and changing the fluid and filter. Dont do one of the Jiffy Lube suck the fluid out jobs. It may not help but sometimes it does. How does the fluid look. Actually that may be one without a stick. Messy to fill.
Good luck
CHet
Old 05-29-2008, 05:17 PM
Trans problems
Yeah it is the one with no dipstick one of the worst decisions gm ever made. I am changing the filter and fluid tonight to see if it helps. Thank you ever so much with your replies.
Old 05-29-2008, 07:44 PM
You are gonna have fun filling it... Not a job for amatuers.
Old 05-30-2008, 08:22 AM
T-bucket23's Avatar
Wiki Edits: 26
Not even close to one of their worst decisions
Its a messy job and if you have a good flex funnel it will make things a whole lot easier
Good luck, I hope it works out for you
Chet
Old 05-30-2008, 10:11 AM
Tranny Problems
Thank you for all your advice. I am going to do the fluid change today because I got rained out last night. I ll defintely go pick up one of those flex funnels before I start. thank you
Old 05-30-2008, 06:43 PM
2000 grand am
First things first. The service engine light is flashing on because it is telling you,HEY there is a problem that needs to be looked at.
Changing the fluid and filter FIRST will only change the amount of money you have in your pocket.
T-bucket23 has given you good advice when he says, have the vehicle scanned.
Old 05-30-2008, 08:15 PM
tranny problems
I changed the filter and fluid today. It wasnt as bad as I thought it was going to be. Im taking it to Autozone to get it scanned tomarrow. I also did a tune up and it made a lot of difference. will see what the scan says tomarrow. thanks
Old 05-30-2008, 08:22 PM
T-bucket23's Avatar
Wiki Edits: 26
What did the tuneup consist of
Old 06-01-2008, 11:05 AM
tuneup
Pretty much standard tuneup plugs wires and air and fuel filter
2002 mercury cougar tranny problems BIGMIKE79 Transmission - Rearend 9 05-12-2007 04:40 PM
1988 K1500 - 700r4 tranny problems JRH Transmission - Rearend 2 04-20-2007 06:16 PM
Serious Tranny Problems DTL504 Transmission - Rearend 8 03-01-2004 08:19 PM
tranny problems joes350truck1 Engine 6 12-15-2002 08:44 PM
Carb vacum for tranny problems. kemo Engine 2 11-20-2002 06:15 PM
