tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 09:05 PM
tranny problems
i bought a 1976 jeep wagoneer with a 401 moter locked up.i put a 360 in its place.runs good but tranny is making a grinding niose when in gear.and does not pull at all.the trannt is a turbo400.it has me confused.front pump?converter? or that shaft the 400 turbo has might be stripped?any imformation will help.
Old 12-29-2005, 07:08 AM
Ozz1967's Avatar
Air Force Guy
Does it grind in all gears? Does it grind if you put it in neutral and rev the motor? Does it leak? If it grinds in all gears (including reverse) you might have damage to the cluster gear that probably happened when the guy you bought it from locked up the original motor. WHen that happened, the engine froze and the entire rotating assembly stopped moving...most likely while the vehicle was in motion which could have stripped one of the gear sets or broke something else inside which gives you free floating debris that could be causing what you hear.
Truth to tell, the only way you'll know for sure is to take it in and have it looked at or, if you know how to rebuild them yourself, open her up and take a look. If it's grinding like you say, it should be fairly obvious.
Old 12-29-2005, 07:23 AM
Denny 9577,
Front pump. Pull the tranny and get this fixed before you do more damage. I think this happened when you did the engine change over. The torque converter slipped forward and came out of the front pump. Then when you installed the 360, the heavy engine pushed back on the torque converter and cracked the gear. I think it is still together but will soon break into two halves and then you are stuck.
Good Luck
Scholman
Old 12-29-2005, 05:28 PM
Frmly sc*ot.
damage to the cluster gear....
Dude,
it's a turbo 400 automatic .
700r4 tranny problems william27103 Transmission - Rearend 14 08-14-2005 11:37 AM
tranny swap problems. rat mac Transmission - Rearend 1 08-05-2005 09:06 AM
Serious Tranny Problems DTL504 Transmission - Rearend 8 03-01-2004 08:19 PM
help with tranny munbers notmrgoodwrench Transmission - Rearend 2 01-23-2004 09:59 PM
Tranny Questions JRS1967 Transmission - Rearend 1 08-24-2003 12:01 AM
