Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tranny Question
Thread: Tranny Question
Old 11-28-2003, 08:23 AM
tm454 tm454 is offline
Tazz
85 Monte with the 377 stroker
This isn't a street car is it?? With a 3200 stall you will burn up the converter on the street because you will never completely hook up till you are at 3200rpm and your converter will be slipping till then. The 200r4 trans, will it require a extra large trans cooler and does it have the deep pan? Some of these racing transmissions arn't suitable for street application either, they shift HARD, not smooth. Might be cheaper to have a trans built with a shift kit and new seals and run the 1800 or 2400 stall. Just and idea, some of these good deals just arn't if the application is wrong.
Todd
Rat Rods Rule!
