tranny shaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2013, 07:09 AM
tranny shaft?
Good morning everyone. I have an 05 taurus I pulled the tranny out of . I found the small spline in the torque converter stripped out, as this is a common problem for these. I am not a tranny person. Are all the shafts coming out from the pump supposed to move freely by hand? The biggest one doesn't move at all. Thank you for any info in advance.
Old 11-24-2013, 08:33 AM
Just about everyone I know including my next door neighbor lady has had the same problem with the ford Taurus or mercury sable. Ford though that since these are not powerful cars, they didn't need those parts heat treated and saved money. Now when you have it rebuilt, your going to have to replace the torque convertor as well. The widow lady next door had it just give out in her driveway. Her son works here at our local Chevrolet dealership. She bought a new Chevrolet because her son told her not to fix it because it would be a few years and it would go out again. The replacement part are no better than the originals. The small end does move a little and the big end you called it, doesn't move. It's solid.
Old 11-24-2013, 08:35 AM
trans shaft
thank you very much. I appreciate your help
Old 11-24-2013, 11:00 AM
Better let you know that you'll have to rebuild the tranny no matter what because all that fine metal particles are going to be everywhere. It may be better to buy a used tranny. But check those splines yourself to make sure its ok. If you do that, make sure you flush all your cooling lines and cooler to get those particles out. Sorry, my mistake, you need to do that no matter which way you go.
Short shaft on long shaft tranny sooper Transmission - Rearend 2 07-07-2010 05:14 PM
How much yoke on the tranny shaft? yragat Transmission - Rearend 4 02-15-2008 07:07 PM
Drive shaft stuck in tranny? Deadtemple Transmission - Rearend 1 10-18-2003 08:26 PM
Tranny shifter shaft seal leaking????? M&M CUSTOM Transmission - Rearend 6 03-22-2003 05:19 AM
Tranny swap, What size tail shaft? Ralph Horak Transmission - Rearend 2 01-12-2003 06:35 PM
