Tranny Shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2003, 09:17 AM
dollybud's Avatar
Lightbulb Tranny Shifting
I have a problem that I need some opinions and help. Its a TH-350 with B&M ratchet shifter. I recently changed the oil and put in Type F as I had read in a post on this board. If I am sitting or just shifting easy while driving it will go 1,2 drive no problem. At wide open throttle it shifts 1 to 2, but won't bang into drive unless you play with it. The cable is fine, and the shifter is well lubed. Could it be the fluid? I know I could change it but would appreciate some comments, thanks.
Tom
Old 08-12-2003, 09:37 AM
willys36@aol.com's Avatar
Wiki Edits: 21
VERY unlikely to be the fluid.
