Tranny slips around a turn - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2012, 10:48 PM
Guys,
I have a 70 GTO I recently purchased and when I turn fast enough around a corner the tranny slips. Anyone ever encounter this before? I think it is a turbo 400.
Mike
Old 07-04-2012, 11:08 PM
Change fluid if you haven't already i had a 75 TA that did that ended up water got in from over flow changed and was fine when i was getting crazy dang i would not do that if i had that car now
Old 07-05-2012, 12:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by mike69 View Post
Guys,
Mike
You sure it's not a faulty limited slip differential? If not, the filter might have come loose allowing the trans to suck air when the ATF sloshes when cornering, or the ATF is low.
Old 07-05-2012, 09:13 PM
pricesgarages's Avatar
check for a restricted vacume line to the modulator also look at the filter its supose to pivot on the mounting bolt
Ram 1500 Tranny slips Ramrunner Transmission - Rearend 1 07-17-2010 04:56 PM
Tranny slips a little 84K10PickemUpTruck Transmission - Rearend 12 10-25-2009 11:21 PM
700r4 tranny slips jerryb Transmission - Rearend 4 12-05-2006 01:54 PM
why does my tranny slip when i turn right? biscotrain Transmission - Rearend 6 07-30-2004 12:13 PM
Tranny Slips when it gets warm! 2506CYL Transmission - Rearend 1 07-09-2004 05:25 PM
