Tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2007, 10:43 AM
mrl mrl is offline
Tranny swap
I have a 62 Pontiac Stratochief(similar to a Bonneville) that came with a SBC coupled to a powerglide. I will be swapping in a mildly modified big block Chevy for more torque, since this is a fairly heavy car. I was thinking of installing a 700R4 to replace the PG since it has an overdrive gear, therefore I could go with a fairly low ratio rear end and retain some decent gas mileage on the highway. My question is, I would like to retain a stock appearance both inside and out, can the stock column shifter work with this tranny, since the PG is a two speed and the 700R4 is a four speed? Would I be able to manually shift through all the gears? Maybe there is a custom bellcrank that would alow this?
Old 02-14-2007, 02:23 PM
I had a 50 Ford that had a flathead originally & was "converted" to a 302/C4.....the linkages I had to fabricate as the throw was different from one to the other.....the selector indicator was another concern...It was all purely fabrication & experimentation, I seriously doubt somebody "makes" one specifically for your application....Time for you to do some REAL customizing...no bolt-ons here!
__________________________________________________ ______Rick........
Old 02-14-2007, 02:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Measure the length of your column....then hit the bone yards and measure some GM columns on some vehicles that used a 700R4 trans. If you can find a column the same length ...then you can swap it out...this way you have the right shifter and could even have a tilt.
Old 02-14-2007, 02:38 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I'm pretty sure that there is a detent kit for the GM column shifters as well as a renumerated indicator. Sorry, I don't have specifics handy.
Check Year One, Lokar, and you might cruise the ads in Street Rodder Magazine, Super Chevy, CarCraft, etc.
It is a common thing to do now-a-days.
Old 02-15-2007, 06:18 AM
mrl mrl is offline
Yeah, I thought about that, but chances are this new column would probably have the ignition switch within the column, for the steering lock. The stock ignition switch is in the dash. Appearance wise, having two switches may look strange. Also this newer column would not look stock. Good idea though, thanks.
Old 02-15-2007, 06:36 AM
mrl mrl is offline
Thanks for the leads. I entered "shift detent kit" in google and bingo!
http://www.shiftworks.com/index.html
I believe these guys have what I'm looking for.
Old 02-15-2007, 06:49 AM
poncho62's Avatar
Wiki Edits: 5
I went from a powerglide to a T350 in my 62 Parisienne........I am using the stock column shifter. You can feek the trsns clicking into the 3 gears, but the numbers don't quite line up. I just set it so drive was on the "D"...
Another concern I would have with the 700R is its length...........It may be long enough that it will hit the "X" frame....Better measure for that first. The T350 fits fine, just had to shorten the drive shaft.
BTW...are you a member of the Canadian Pontiac Club?
http://autos.groups.yahoo.com/group/...anpontiacclub/
Old 02-15-2007, 08:36 AM
mrl mrl is offline
Holy Shoot! Good point, I hadn't thought of the longer length of the 700R4. I was really hoping to have an overdrive gear. I guess my only option would be a Tremec. What about a lock up torque converter? Doesn't it reduce the rpm's on the highway or does it just simply lock the final gear (1:1 for a TH350)?
BTW, yes I am a member of the Canadian Pontiac Club: a62strato. Great site.
Old 04-09-2007, 12:39 PM
mrl mrl is offline
Poncho,
I am going with the th350 swap. By how much did you shorten the driveshaft. I figure about 2". Does that make sense? The PG mesures around 25.5" and the th350 with 6" tail is 27.7". Also, does the transmission mount have to be moved back or does an adapter/plate have to be fabricated?
Regards.
Old 04-09-2007, 04:13 PM
poncho62's Avatar
Wiki Edits: 5
I don't remember how much I had to shorten it......15 years ago. Best to put it in, and them measure how long a shaft that you need.
The tranny mount is in the same spot as the Powerglide.
Old 04-09-2007, 06:24 PM
mrl mrl is offline
ok, thanks. Your Parisienne was for sale, did you sell it yet?
Old 04-09-2007, 06:40 PM
poncho62's Avatar
Wiki Edits: 5
No....found a job instead, so am keeping it for a while.
Old 04-09-2007, 07:44 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
Aod
On my AOD swap into my 57RWag. The AOD has it's detents internal,so we were able to use bell crank from donor car.By having adjustment from 59 two speed colume too belcrank and from belcrank to trans with HEMI joints all gear postion came thru.Yea,I know it's a FORD!!!!
Old 04-09-2007, 10:26 PM
I installed a later GM column in my 61 ventura. Cut out the key switch area and fill it. You'd never known I did mine if I had not mentioned it. Mike
Old 06-19-2007, 02:01 PM
mrl mrl is offline
The th350 is in. I bought the proper transmission yoke for the th350 (the powerglide had less teeth on the output shaft). Now I need to shorten the driveshaft. What is the minimum length that the trans yoke must be into the tailshaft of the th350?
4x4 85 ranger windsor swap and need to change tranny gothrod87 Transmission - Rearend 4 03-27-2006 08:29 PM
third gen camaro tranny swap krzy erl Transmission - Rearend 4 06-14-2005 10:21 AM
tranny swap...whats better chevy82 Transmission - Rearend 2 03-09-2004 04:37 PM
manual tranny swap chevyIIdie4 Transmission - Rearend 1 05-13-2003 09:09 AM
