tranny swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2012, 10:32 AM
tranny swap?
Im considering swaping a turbo 350 into my 91 short bed 2wd 1500, It has a 5 speed now that detonated and im not having any luck finding a used 5 speed in my price range. Has anyone attempted this or done it?Is it possible? I Know the yoke is different and I can fabricate a trans mount plate but was wondering if thats all the fabrication required. I have a short tail shaft tb350 from a late 70s camaro for the swap. any feed back will be really helpful.
Old 04-10-2012, 08:36 PM
GMCBEAST's Avatar
I swapped the original 4L60E in a '93 Chevy short for a TH350 shorttail and along with making a mounting plate I also had to have a driveshaft made for it. Just out of curiousity where are you located?
Old 04-10-2012, 09:48 PM
i have a 90 chevy short wheel base. i swapped 5 speed to 700r4. You just got to make sure you have tranny lines, shift link, i tried the pro shifter had too many problem i had to go to junk yard and get the factory shift link and also change steering column but yes it can be done but i cant get my speedometer to work.
tranny swap hman17024 Transmission - Rearend 19 05-05-2011 07:36 AM
Tranny swap/ rearend swap? aggar Transmission - Rearend 2 03-16-2008 03:07 PM
V-6 To V-8 Tranny Swap roxxxi Transmission - Rearend 4 11-09-2007 05:07 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 01:21 PM
Tranny Swap Outlaw Transmission - Rearend 1 07-27-2002 06:14 AM
