Tranny Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2002, 09:39 PM
Wiki Edits: 3
Post Tranny Swap
Im sure everybody here has this question before and i would like some help. im building a 71 Chevelle street rod and it has a TH350 i think and i would like to swap to 4 speed. any help on how hard or costs would be appreciated. thanx
Old 07-27-2002, 06:14 AM
Post
Not to bad especially if you a donor car same year. I just finished my 67 firebird, had a turbo
400, and put in 4-speed. For mine all my linkage
underneath, bolted to frame(my frame had hole location already there)Pivot arm bolts to frame other side pivot arm is pivot ball bolt.The clutch
pedal slide on don't forget the retaining clip. same crossmember, standard and 350 I believe are same lengths(maybe different yoke, maybe same yoke)You're rear-end gears are extremely important
if say you have 2:56 you're going to have to change complete rear ends to say 3:08,3:23,3:55
I'd stay away from 4:10,4:11,4:56, If you like
to drive your car. You're Chevelle should be quite similar, Donor cars are a good time saver
especially if it's optioned the way you want.
Hope this helps if there's anything I can help
post or e-mail. good luck, (by the way, my firebird 67-convertible, 428 HO, 4-speed, 3:55
limited-slip rear-end, feels like I added 100 HP
also car has factory cast iron headers, and a 455
polished aluminum intake,
