Tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2002, 08:51 AM
Post Tranny swap
Is there a 4 speed manual transmission that could be installed in a 1971 Lincoln Mark III?
Old 09-26-2002, 03:34 AM
woodz428's Avatar
Troll Hunter
Post
A Ford top loader with the associated parts (bellhousing,flywheel,etc.) should fit right in. The biggest problem will have is a clutch pedal and linkage assembly. Since these and the Thunderbird shared the same platform and neither were equipped with a stick, you'll have to fabricte or adapt something. Compare your brake pedal hanger assembly with a manual shift Torino or equivalent and you might be able to swap those in.
