Tranny swap 94 silverado 2wd 4L60E to a 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 05:50 PM
Hi Im swapping the tranny in my 94 chevy truck it's got a 4L60E in it and I've had nothing but trouble out of it so I'm wanting to put a 700R4 in it has anyone done this b4 or know the specifics on what will need to b wired up on the new set up? Thanks
Old 12-27-2011, 10:04 PM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hello and welcome Nathan! This is the Introductions section, so not many members come through here. If you post you questions under the Transmission - Rearend section over at the Forum, you'll get plenty of help. Welcome aboard!
Old 12-28-2011, 02:10 AM
nine4gmc's Avatar
if I'm not mistaken, the only difference in a 94 4l60e and a 700r4 is the detent cable and speedometer cable. Your 94 will not have cables, I know and a 95 up will not work without modifications, only a 93-94 will be a direct swap.
Old 12-28-2011, 03:07 AM
Tranny swap
Well the 700 has a tv cable and both have the same speedo plug in so it's really just the lock up converter is what I need to make sure about! I'm bout to just put it in and figure it out the hard way I guess? I've been reading and a lot of different answers across the board so I'm goin with the simple ways first! Thanx alot 4 replying I really appreciate u!
4L60E swap to an 700R4 Brass Monkey Transmission - Rearend 3 06-16-2011 04:27 PM
700r4 to 4L60E swap chevy_c10 Transmission - Rearend 19 05-10-2009 08:30 AM
Tranny (4L60E) problem on a Silverado AlwaysCanadian Transmission - Rearend 2 10-15-2008 07:14 PM
will 4l60e work in my 89 silverado? It has a 700r4. mojokimble Transmission - Rearend 2 04-21-2006 08:16 PM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 01:52 PM
