tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2002, 04:21 AM
New Member
Post tranny swap
i have a 79 gmc 1/2 ton 4x4 with a 3 speed automatic. the problem is that i run real high rpms at about 65 mph wick really kills my gas mileage. i have a 350 ci engineand i want something that will give me a little lower rpm at higher speed with out killing my low end torque too bad. and also how hard would it be to convert to a manual trans.
Old 12-10-2002, 07:57 AM
Post
The only problem with a 4 speed swap would be that it might have lower gears then you auto. The best way around this would be to change gears in your front and rearend, or even taller tires might work.
Old 12-10-2002, 01:11 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
[quote]Originally posted by Bigblazer:
<strong>The only problem with a 4 speed swap would be that it might have lower gears then you auto. The best way around this would be to change gears in your front and rearend, or even taller tires might work.</strong><hr></blockquote>
Three speed autos are 1:1 in high gear. A 4 speed standard will be the same in high gear, unless you go with an overdrive.
An auto overdrive would be a good choice.
Chris
Old 12-10-2002, 04:17 PM
sst4530's Avatar
New Member
Post
I would persue an overdrive unit as well. A late model 700r4 has I believe a .7 or .8 to 1 ratio in overdrive.
