Tranny swap, What size tail shaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2003, 11:35 AM
Post Tranny swap, What size tail shaft?
If I put a earlier model v8 with a th350 into an 84 camaro and used the hurst or b&m adaptor. What size tail shaft should there be on the th350 so everything bolts into place?
Old 01-11-2003, 01:39 PM
Post
if the car came with 700r4, use a long tail, same lenginth
Old 01-12-2003, 06:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
you will need a T-350 with a 9 inch tail housing on it. Measure the tail housing from where it bolts onto the main tranny case.
The T-350 was built in 5 different lengths from GM.
2 different length 4x4 output shafts, then 6 , 9 and 12 inch tail housings.
Tony
