tranny temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2005, 12:20 PM
tranny temp gauge
I need to know what side to put the tranny temp gauge on my tranny. I have a 700r4... The fluid inlet side or the outlet side.. and then what is what, as in is the top cooler line fluid out or fluid in...
Old 04-21-2005, 12:37 PM
malc's Avatar
Living At The Speed Of Life
I installed mine in the front of the pan, after trying to install it on the linkage side .For cooling lines in and out go here http://www.tciauto.com/tech_info/cooler_fittings.htm
Old 04-21-2005, 05:59 PM
I put my sender (electronic gage) in the pressure test port.
If you have a mechanical gage it won't fit there.
Old 04-21-2005, 08:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
top cooler line is fluid return from the cooler. You do not want the temp gauge there. Fluid out line will give a false high temp reading since this oil is directly out of the converter
Install the temp sender in the pan or main case...
Returning fluid from the cooler lubes the tranny parts and cools them too.
as the fluid drops to the pan after lube & cooling this is where the tranny temp is best taken.
Old 04-21-2005, 09:58 PM
Do you think I mine is in an acceptable location?
I've had many people tell me that in the pressure test port will give false high readings and that the only right place to put the sender is in the pan. I don't see that the fluid could gain that much heat after only going to the pump but the main reason I put it there was it was just 'too easy'.
Old 04-21-2005, 11:08 PM
New Member
In the pan
Old 04-22-2005, 01:27 AM
malc's Avatar
Hereīs mine brazed in at front.
I found a pic of the trans left side without the pan to help show where itīs cluttered with shift linkage, and the right side fairly clear.
(Left side being driver side)
ID:	4726   Click image for larger version
ID:	4727   Click image for larger version
Old 04-22-2005, 07:02 AM
cboy's Avatar
Last journal entry: Finished
Would it be possible to install the sender in the pan just using gasket washers rather than brazing?
Always learning...and sharing what I've learned.
Old 04-22-2005, 08:56 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
installing the sensor that way... they usually leak
Old 04-22-2005, 09:07 AM
The problem is that you can't really find fittings without the tapered threads. It is hard to get just the right thickness. If you want to try you could get a 1/8"NPT x 1/4"NPT reducing bushing and a short 1/4"NPT female coupling. If you have a NPT tap you could tap the coupling deeper. I would then just clean it up real well and install it with JB-weld.
Being lazzy the pressure test port looks real good! You don't even have to drop the pan
Old 04-22-2005, 09:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The pressure port will function well for the temp of the tranny.
I often use aluminum tranny pans which can be drilled , tapped for the temp sensor
Old 04-22-2005, 11:27 AM
temp gauge
so the sending unit will screw right into the pressure test port...
Old 04-22-2005, 11:47 AM
As long as it is a electronic gage it will (at least my Autometer one did). The pressure test port on a 700r4 is 1/8" NPT and the sender is also 1/8" NPT. You don't even need an adapter. It took me about 2min to install the sender and another 5hrs to run all the wires and mount the gage
Mechanical senders are much bigger then the electronic ones. They are 3/8" NPT to 1/2" NPT and won't fit in the pressure test port.
No matter how you mount it don't use teflon tape on the threads because the housing needs a good ground to work right. I used some liquid teflon sealant on mine.
Old 05-27-2005, 11:49 PM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
I'm very glad I found this thread. One more question. I'm about to buy some Auto Gauge gauges for my project amongst others an oil temp gauge which I would like to use for my 700R4.
Am I assuming right in that an oil temp gauge can be used on either the transmission or the engine depending on your needs?
Old 05-28-2005, 12:26 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
temp gauges designed for use in liquids will work in engine or tranny or ? Just so the temp probe is covered in a liquid for proper temp reading is the way I understand it.
I have an Auto Meter tranny temp guage in the engine block of my 1961 Dodge Lancer. I had the tranny temp gauge & I am too cheap to buy another guage...
You will notice the temp range ( low to high ) is usually different from a water to oil temp gauge.
190*F is 190*F any way you read it . LOL
Possible for autometer temp gauge to be bad? fouroheight68 Engine 8 02-21-2005 12:20 PM
Coolant Sensor? Temp Gauge what do you think? my350camaro84 Engine 1 02-14-2005 08:50 PM
Which temp gauge is more accurate Palmtrees57 Engine 3 10-30-2004 07:38 AM
Temp gauge grandprix601 Electrical 2 03-17-2004 09:45 AM
1950 Buick temp gauge in engine stuck! reluctant_paladin Engine 1 04-10-2003 09:49 AM
