Tranny temp gauge sending unit location - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2008, 12:59 PM
HI
I'm going to be installing a trans temp gauge ,and am undecided where to put the sending unit. I don't think I can put it in either line that goes to the cooler,because they are rubber,and wouldn't give it a ground. Don't really feel like drilling&welding on the pan, wasn't planning on taking it off. I heard somewhere that on a 700-r you could screw it into the case somewhere. what I want to know is if there is a place on a turbo 350 case where it could be screwed into?
Old 12-26-2008, 01:15 PM
Last journal entry: 50 Ply wagon
I put mine inline with the hoses. All you have to do is get a TEE fitting that has the same thread as the sending unit, which is usually 1/8" NPT. Then just adapt a piece of line from each end and the connect the hoses back up. I don't know about the 350 chev trans for fittings. not a chevy guy here.
Old 12-26-2008, 01:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
is it a 1/8 inch pipe thread sized sensor?
in the pan is best.
Next location : thread it into the rear port on the passenger side of the t-350 trans... just above the pan rail. Remove the plug that is there
you do not want the sensor in the cooler lines.
Old 12-26-2008, 01:50 PM
Thanks,you wouldn't have a pic of where that plug is would you?
Old 12-26-2008, 02:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
port is in front of the circle marked modulator - vacuum ... Red line around the port
Old 12-26-2008, 02:36 PM
Thanks a lot Crosley!
I think most of the senders I see are 1/8 pipe,I'm assuming that is also the thread where that plug is,is that right?
Thanks again
Gary
Maybe I shouldn't have said they are 1/8 pipe,I think maybe I was assuming that
looking at B&M gauges at summit---they don't say what size
Old 12-26-2008, 06:08 PM
boatbob2
trans lines to cooler...
Hi,i would replace the rubber trans lines with metal lines,NAPA has them...
Old 12-26-2008, 06:28 PM
WHY??
Old 12-26-2008, 10:09 PM
SSedan64's Avatar
WHY??
Much more durable. If your drag strip does any inspection, rubber hose don't cut it. Hope your not using gas hose. At least use trans hose.
Old 12-27-2008, 06:09 AM
I'm using trans hose and its not a race car ,just street-hotrod
Old 12-28-2008, 03:49 PM
Originally Posted by Crosley
is it
Why not?
That is the actual temp coming out of the trans.
The trans people (BM, TCI, etc)recommend keeping the trans at a controlled temperature using an inline H thermostat of 190*, as sold by Summit, Jegs.
Old 12-28-2008, 04:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by ScoTFrenzel
Why not?
No...... cooler "out flow" it is not the actual temp of the transmission... it is the fluid flow out of the torque converter where almost all the heat is developed. That temp reading can be quite high at times.
the best place for temp reading is in the transmission pan..... as the cooled oil returns to the transmission it enters the lube circuit. The fluid then washes the heat way from the parts of the transmission as the fluid also lubes the parts.
the fluid in the pan indicates a more true temp of the parts. just my opinion.
A fluid temp from 150 to 180*F will be fine. That will burn off the condensation inside the trans too
Old 12-28-2008, 04:12 PM
Just asking:
I do agree with you that the output line is the hottest place because the torque converter is spitting out the highest temp. Especially during stall.
Seems to me that as fast as the oil is circulating that the oil in the pan doesn't have much time to cool anyway.
Isn't that why the custom transmission companies recommend a 190* thermostat in the cooler line?
Engine as well as tranny thermostats maintain a MINIMUM temperature being closed until the trans output hits 190* then opening to add needed cooling.
I just kind of figured that since they recommend this for their $3000 trannys that maybe it is a good idea.
That is what they say, anyhooo.
I am not a tranny man, and I can't tell you where the sending unit on my new TITAN 5.7 truck is located. It might be different than what other companies recommend.
What I do on rods is install a thermostat and a BIG cooler and ignore the temperature since I know it will be 190* minimum and whatever the cooler can provide beyond that.
Sending Unit Not Working ???? cashflow55 Electrical 7 10-11-2008 07:56 PM
Temp sending unit busterwivell Hotrodding Basics 5 09-16-2008 07:26 PM
no room for oil sending unit murrsue Engine 4 01-28-2007 12:06 PM
sbc temp sending unit location? joe k Engine 3 07-12-2005 01:02 PM
Where can I install my water temp sending unit? CHEV66JB Engine 1 05-11-2003 06:15 PM
