Tranny Temp Guage = Oil Temp Guage? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2007, 07:12 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
I have a set of electronic guages in my car from the local wholesale store(Princess Auto). They aren't the cheap $10 for 3 guages, they're almost $30.00 each. They seem to work great the only problem is they don't have more exotic guages such as tranny tempurature. Mind you they got boost and air fuel ratios for all the ricers out there and people trying to turbo their cavaliers...
Anyway, right now I have engine oil pressure, water temp(in head), voltmeter, and tach. I'm hoping to build a center console very soon which will hold 2 more guages. I was thinking an engine oil temperature and a tranny temperature guage. Can I just buy another oil temperature guage and put it in the tranny pan?
I'm running a stage 3 th350 with a full manual valve body and 2500 stall converter. By Sept there will be a 400-450 horse 350 turning it. I would like to keep an eye on temperatures.
Here's a picture of my guages right after I put them in. Yes I've cleaned my car since these were taken
http://www.renowneddesign.net/nova/s..._installed.JPG
Old 06-21-2007, 07:50 PM
Jmark's Avatar
Yes, you can use the oil guage and sender for the trans. You'll just have to make a place in the pan, below the fluid level, to install the sender.
I"m also glad you cleaned the car!! LOL
Old 06-21-2007, 09:59 PM
topdogger's Avatar
Newskool
Thanks,
I just wanted to make sure before buying another guage. Some automotive fuels have weird after affects on parts that weren't designed for specific uses.
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 03:34 PM
oil pressure guage brian400ex Engine 6 04-16-2004 01:18 PM
Engine oil temp question. Blown72Camaro Engine 3 08-27-2003 11:28 AM
temp guage: up and down, and up and down! bullheimer Engine 5 03-18-2003 08:33 AM
temp guage want work 70 nova Electrical 1 02-23-2003 11:51 PM
