Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
#1
Alittle1
127 edits
#2
Powerrodsmike
113 edits
#3
Techinspector1
103 edits
#4
Oldguy829
80 edits
#5
Chevythunder
50 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-08-2008, 02:12 AM
aw1950 aw1950 is offline
Tranny - transfer case grinding question
Hello I have a 4wd that when it is running I cant shift the 4wd from low to high or anything. All I get is gear grinding. Sounds like as if your were trying to put a standard trans. in gear with no clutch engaged. I have the instection cover off of the floor and when I shut off the truck I can hear the transmission spinning for a couple of seconds. I should note that I cant put the trans in park when it's running either. Any suggestions? Also I should note that the fluid is down a little . I dont think that should have an effect like that but who knows???
Old 05-08-2008, 03:38 AM
F&J F&J is offline
re: Tranny - transfer case grinding question
More info needed.
If it's like my 205 transfer case with auto trans; it would do all that if the T-case was in neutral.
With motor off, and in park, can you shift the T-case into gear??
Old 05-08-2008, 05:10 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
Give us a clue of the vehicle.
If the transmission is not in park , then the transfer case gears are turning if the engine is running.
If you find yourself in a ditch.... down shift!
Old 05-09-2008, 02:07 AM
Transmission
Yes, to tell you what I have would help.DUH!! It's a 1986 Ford F-150 with a 6 cyl. 300 .I dont know what model number transfer case it is . But I do know that the transmission is a c-6. Thanks for your input .
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Tranny - transfer case grinding question"
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 06:36 AM
transfer case dbarnes Transmission - Rearend 2 09-16-2005 06:26 PM
350C tranny question mkopsick Transmission - Rearend 2 09-10-2004 09:09 PM
76 chevy transfer case purplePeopLEater Transmission - Rearend 5 12-15-2002 09:54 AM
Aluminum Transfer Case Bigdude_79 Transmission - Rearend 2 12-06-2002 08:23 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
