Tranny vibration over 90 mph? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2003, 05:16 PM
Post Tranny vibration over 90 mph?
I have a 1969 Camaro with a 302 and a saginaw 4spd. I think that the problem lies in that I changed the tranny from a turbo 350 to the saginaw and left the original driveshaft and yoke from the turbo 350. When I reinstalled the driveshaft I noticed that the yoke lacked about 3/4" of mating where the yoke fit in the turbo 350. Is this my problem? Do I need to get a new driveshaft made? Or can I just find a longer yoke at a salvage yard? Or could the problem lie in the tranny?
Eli
Old 04-13-2003, 05:26 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
How is the tail bushing in the Saginaw, if it's worn that'll do it. This may sound funny, but try pulling the driveline loose from the pinion saddles and rotating it 180 degrees then install.
Old 04-13-2003, 06:26 PM
airworld2's Avatar
Post
sound like drive shaft is too short, yoke only need 1/2 t0 3/4 inch travel. if you see where 350 tail bushing and rear seal had been find a longer shaft or have new one made if that puppy comes out at 90 mph with out safety loop in the foor pan your in for one hell of a ride. think of the others around you as well....
airworld2
Old 04-13-2003, 06:42 PM
Post
Thanks guys. The tail bushing is brand new. The tranny had just been rebuilt prior to the install.
Thanks again,
Eli
Old 04-14-2003, 04:21 PM
Post
I'm reaching way back, but I recall Camaro having a drive shaft that was put togheter wrong at the factory, the cups were 1/4 turn off line, didnt feel as much with auto but 4 speep has a more solid hook up, Just a foggie wave that came to the top on Camaro drive line. Good Luck. JF
