Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which tranny will bolt up to mopar flat 6?
Old 08-14-2006, 12:12 PM
redlightning's Avatar
redlightning redlightning is offline
Mike,
If it locks up on you while driving.Pull over and set the e-brake or block it up so it will not roll on you.Crawl under it to the trans and put both levers in the middle position(neutral).This should un bind it so you can get home.
I don,t know the about old mopar trucks ,if there is an adjustment on the arms.Do the same ,put both arms in the middle and put the shifter in neutral then adjust them until they are not binding.
This works on the old fords,also those cheap floor shifters work just fine also.That,s what I had in my 54 when I was in high school.I don,t know about an adapter.Carl
I just reread what jalopy45 wrote.He looks like he knows something about your mopar.What I put above was working on fords.I still think you adjust it in neutral if anyone disagrees please correct me.Carl
