Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tranny yoke clearance
Old 04-16-2002, 10:47 AM
Stinkin_V8's Avatar
Stinkin_V8 Stinkin_V8 is offline
Suburbanite Member
Post Tranny yoke clearance
How much clearance should a guy have between the rear seal on the tranny (actually the transfer case in my case) and the yoke on a street-only vehicle? The shackles on the rear springs are on the back, so with compression it should lengthen the wheelbase right?
I suppose an easy way to tell if I've got enough room is to jack the rear end up from the frame so the wheels just hang there, this should be the shortest the wheelbase will ever get.
Whatcha think?
When life hands you lemons, ask for tequila and salt
