trans. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2003, 08:57 AM
Talking trans.
i have a 34 ford with a 350chev with 350hp with a 700r4 tran. when i get on it my tran shifts at 4000rpmin first,3900 in second.what rpm should it shift at (mabey 4500 to 500rpm?).if so how do i adjustit?
Old 01-29-2003, 01:12 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
You can adjust it via the throttle cable but don't do it by ear. These trannys are very sensitive to TV cable setting and can be easily fried if not set very precisely. Contact
<a href="http://www.bowtieoverdrives.com" target="_blank">www.bowtieoverdrives.com</a>
They have an adapter that allows adjusting shifts properly.
Old 02-03-2003, 08:13 PM
Post
ROBBIE...... did you or your dad ever live in michigan?
