Ive got a 350 in my drag car at 520 hp and it holds up fine. Has a trans brake and a couple after market parts but still basically stock.
I would use a 400 Turbo and be sure ... When it doubt ... make it stout ... Deuce ... |
Trans for 500+ hp in a 3500 LB car
Street car,or race car,or both. We have run thm 350"s behind big blocks with good results. The 400's,well everybody knows how tough they are.
If this is a race application,check out Jhon Kilgore transmissions. His th400 reduces 30LBs of rotating mass. |
KIlgore's trans is intended for class racers (Stock, Super Stock, Comp) not bracket cars. It is an excellent trans, but I doubt he is looking for a $6000 bill.
Nastynova; Use the T350. Use a GOOD valve body (manual, either forward or reverse) and ask the manufacturer about other mods they would recommend. I have several ideas... |
trans rear-end question
I have a 36 Chevy panel with a blown 468 which is right at 800 HP....Never weighed it but it's probably less than 3500 lbs.
I run a turbo 400 with a 2800 stall converter, with a Ford 9". No problems of any type. |
Rossler builds a nice t-400..... about 5500.00 IIRC
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I have a fairly healthy 350 with a small blower in my K5 Blazer. The T350 is stock except for a B&M Shift Improver and 2400 RPM converter. It's a 4500lb 4x4 and the tranny has held up just fine for almost a year now.
| 66 Impala 530 HP SBC | black66 | Introduce Yourself | 1 | 10-12-2004 02:04 AM |
| Building BIG HP 400 SBC | Sampson | Hotrodding Basics | 11 | 04-04-2004 12:52 AM |
| Story time. | Halloweenking | Hotrodders' Lounge | 17 | 05-19-2003 10:16 PM |
| 327 sbc w/350 hp cam overheats/stalls | pircjo | Engine | 10 | 05-11-2003 07:18 AM |
| 350 or 383 in 3650 lb. car ? | laitch | Engine | 1 | 03-24-2003 02:05 PM |
