Trans Am Rear Sub Frame Rails Are Rusted out - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2011, 02:40 PM
valtiel43's Avatar
I have a 1980 Trans Am in great shape except that the rear subframe rails are rusted out pretty bad. The body isn't twisting or sagging yet but it will probably happen eventually. So I'm wondering what kinda process it would be to swap in a new rear subframe. I really don't wanna scrap this car, it's too nice for that. But I'm no expert mechanic either.
A guy told me it's really easy and you just undo some bolts in the trunk and a few others and the whole rear end and subframe rails will come out. But then I've heard that you need to cut the old one out and weld the new one in. I can't weld but I know a guy that can, and I was thinking what if I got him to patch up the current frame with some metal. Would that be a good idea?
I found this on Jegs, http://www.jegs.com/i/Competition+En...3013K/10002/-1
Would that be what I need to replace the rear frame rails?
Here's a pic of the drivers side: http://i42.tinypic.com/2ez789d.jpg
Any help is appreciated.
Old 11-16-2011, 04:53 PM
Last journal entry: There's always time to do it over...
Uhhh, they guy who told you that was wrong. You can fix it, but you need some basic welding and fabrication skills.
Old 11-16-2011, 04:56 PM
poncho62's Avatar
Wiki Edits: 5
There is no rear subframe like on the front of that car....The frame structure is part of the floor pan/body.
Ontario Rodders
Old 11-16-2011, 08:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by valtiel43
I found this on Jegs.
Those pieces along w/possibly a new trunk floor will do the job- but like the ad says- "Note: Welding and fabrication required".
There are other more complicated rear suspension set-ups like 4-links, etc. that could be used, but they will require even more fabrication and money to do right. Guys tend to use them if a high HP engine and drag racing are the plan, along w/a roll cage and tubs to fit wide tires w/o fitment probs. If you just want to replace the bad metal, the simpler replacement parts will work.
Removing rear frame rails ricksautorestoration Body - Exterior 7 09-07-2009 08:18 AM
narrowing rear frame rails 48chevycoop General Rodding Tech 6 03-29-2008 12:41 PM
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 08:02 PM
Need advice on replacing rear frame rails. RPB-71' Camaro General Rodding Tech 12 09-22-2003 06:38 PM
Replacing camaro rear frame rails 72camaro Body - Exterior 6 05-28-2003 04:54 PM
