Trans Am starting issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 08:42 PM
sideshowbh's Avatar
I have a '77 Trans Am with the 6.6 Litre engine. The problem I am experiencing is after it sits a while ( usually weeks ) and the battery goes dead, after charging it with a battery charger, It wont start. It gets no fire to the plugs. After unplugging the hot wire to the distributor cap for 10 or 15 seconds, and plugging it back in, It fires right up. Anyone ever experience this? Thanks, Bob.
Old 04-21-2012, 08:52 PM
Ifit aint fix...Don't broke it
Last journal entry: I am ALIVE! 65GTO FRAME OFF
starting issues
your resetting the ignition module. 2 options.....install a disconnect on bat hot lead or keep trickle charger on bat. i use a solar charger.
Old 04-21-2012, 08:58 PM
sideshowbh's Avatar
Thanks GS. I am thinking of using a solar charger. It usally stays parked for weeks at a time.
Old 04-21-2012, 09:46 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Unless you have something draining the battery (stereo, amp, etc.) or the battery is getting old, it should not discharge while setting. You need to find out what is draining the battery.
Old 04-22-2012, 06:31 AM
Drain
unless you have a ton of time it is almost impossible to find the small drain on the battery on these cars, I have owned 5 of these and had the exact same problem on all of them. I am pretty sure it is in the ignition ckt somewhere but the wiring is so ponderous on these cars it is very hard to deal with, solar charger much easier.
Old 04-22-2012, 08:37 AM
T-bucket23's Avatar
Wiki Edits: 26
This is the right answer. With the right tools if there is a draw you should be able to pin it down is short order. Its not hard you just need to be methodical. I good quality amp meter is the key to locating this type of issue.
Chet
Old 04-22-2012, 05:09 PM
you would think
Its not that simple,,, there is no amp draw for 3-4 days on these cars but for some reason if you don't start it the module grounds out and drains the battery.. It is a mystery to me and it only happens in factory 6,6 Pontiac.
I suppose you could try a pertronics unit but it may be something else or a combination of things. If it were just a simple continuous drain it would be easy to find. I spent my whole life fixing complicated electronic and electromechanical equipment and never did figure this one out. spoke to many mechanics who told me the same thing. When I moved the motor to another body (firebird) the problem stopped...????? All 5 of my 6.6 ta did this.
1967 Starting issues Kent67 Electrical 5 08-14-2011 11:23 AM
i am having starting issues with my 350 83chevytruck Engine 3 04-12-2011 08:27 PM
Need help - starting issues RickyDoors Engine 18 03-26-2011 10:03 AM
92 Camaro Starting Issues 41CHEVYCOUPE Electrical 1 12-13-2008 01:26 PM
283 starting issues 283jeep Engine 17 04-03-2007 11:48 AM
