trans am turbo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2007, 03:17 AM
Checy_Guy's Avatar
trans am turbo?
whats this turbo off of?
Chevy-Rules
Old 03-03-2007, 07:47 PM
n00b's Avatar
try this site looks possible
http://images.google.com/imgres?imgu...3D10%26hl%3Den
Old 03-03-2007, 07:57 PM
Wiki Edits: 31
That is off of a Carburated Turbo Buick 231, made pre '83. there are a couple varaitions, but they all used a 550 CFM, Draw Thru Rochester Qjet ( externally refrenced to boost ). this is a diffrent varaiation, stripped down to just the turbo. I got this as a freebie, but it's in excelent shape. it's going on my Ford Falcon 200 I6. there All T3's, but there real trim size changes a bit.
Old 03-04-2007, 06:53 AM
bondo's Avatar
I've got a couple 3 of those,.....
I'm told they're off a 301 Pontiac,....... Early 80s vintage.......
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Choose Pontiac 400 or 455? & Turbo Questions TheMonkey Engine 33 08-11-2009 11:01 PM
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 02:56 PM
Turbo 350 Trans cooler Redshiba Transmission - Rearend 3 09-02-2002 09:17 PM
