Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - which trans for this application?
Old 05-09-2011, 04:06 PM
Ray Bell Ray Bell is offline
A833...
There are Chevy bellhousings for them, but they're for the overdrive model. Get that bell, then get an earlier trans with direct top gear, you have to make a spacer ring to go around the input bearing retainer and grind the nose off the input shaft.
These are stout trannies... especially the '70 to '74 versions, or if you want real strength, find an 18-spline input model, they were built for the 426 Hemi.
