Trans bad in drive. Good in first. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2004, 05:44 PM
Hello to all.
I have a 98 Plymouth Voyger with a 3 speed auto trans.
When put into drive the van must be reved to get it to go from a stand still. (really sloppy) When put into 1st it has no problem from a stand still. Can anyone help with an explantion and is this mean a new trans?
Matt.
Old 02-10-2004, 04:58 AM
airworld2's Avatar
shifting trouble
as long as you are speaking of 3 speed trans not the 4 speed, governor would be the fist thing I would suspect here. most case torque converter clutch has gone bad, or planet failed.
airworld2
Old 02-13-2004, 05:28 PM
Ok, now the van is good in first while in drive, but will not go into second. I changed the fluid with the correct type before posting the first time. It's weird that it wasn't working before in first but now is.
This all started about five days ago. I believe that someone put 1 quart of dextron type fluid in, but i can't imagine who. To quote the great "Charley Brown" uuuuuuug!!!
Airworld2, I appreciate the reply. I'm just hoping that with this new info that there might be something that can be done short of a rebuilt unit.
Still hoping. Matt
