Trans Brake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2011, 02:26 PM
clance54's Avatar
Trans Brake?
Whats need to install a trans brake in a transmission? Is it just the soleniod or do you need the whole valve body to do it? Any help im grateful for and thanks ahead of time.
Old 07-25-2011, 10:04 PM
tranz brake
what trans is it for,full tree or pro tree and yes its a valve body too and some internal mods are also needed for it to work need more info on car,motor and weight also
Old 07-25-2011, 10:49 PM
clance54's Avatar
700r4 70 Impala Pro stock weight is unknown
Old 07-25-2011, 11:25 PM
Overdriv's Avatar
I inquired about putting a trans brake in a 700R4 several years ago. No one seemed to think one was even available, might be now, but it was a general consensus that the 700R4, even though can be made to handle big HP/TQ, it's just not the trans for a brake.
Really, why a 700R4, when a 400 with a brake is commonplace, or a powerglide with a brake.
With pro-stock power, I doubt the 4th gear, OD, would last long no matter what has been done to the trans. Depending on how much power you are talking about, a Bruno, or something similar might be in your future.
I would suggest you call around to all the major builders that specialize in OD transmissions. Ask them if such a thing is doable.
Old 07-25-2011, 11:34 PM
clance54's Avatar
Mainly for the overdrive for occaisonal street driving. But from what I'm seeing its gonna be a th350 or 400 due to lack of aftermarket parts for the 700r4
Old 07-26-2011, 07:13 AM
Overdriv's Avatar
Did you find any information on a brake for the 700?
Old 07-27-2011, 04:12 PM
SSedan64's Avatar
I still don't know of anyone making a Brake for a 700R4. The splines in the aluminum Input Drum can't handle the shock. They are also know to crack where the Input Shaft is pressed in. I don't think anyone makes a Steel Drum for it, wouldn't be cheap, this is a large part & Steel = heavy.
http://www.sonnax.com/system/announcement/77733-01K.pdf
Trans brake? Backwoods Transmission - Rearend 3 12-13-2010 10:46 PM
c6 trans brake 84 k10 Transmission - Rearend 4 12-05-2010 10:02 PM
TH-400 trans-brake braditude63 Transmission - Rearend 1 08-31-2010 07:43 PM
Trans Brake 101 We B Racing Transmission - Rearend 2 08-28-2007 10:12 PM
best trans with a brake for a sbc nastynova Transmission - Rearend 3 08-02-2006 09:58 PM
