trans cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2006, 11:55 AM
trans cooler
i am installing a cooler on my tci 350 trans. in a 1969 chevy truck.I have a radiator with coolant lines at the top and bottom, my question is what line would be the return line?
Old 10-06-2006, 03:44 PM
This is a very good link that I have posted up many times here.
http://www.tciauto.com/Products/Tech...r_fittings.asp
TCI has some very good tech info for trannys on their web site.
To help others that search:
Trans. Transmission Cooler ATF fittings fitting pipe thread flare flair pressure return hot cold flow in out upper lower th350 th-350 turbo 350 th-400 th400 700r4 4l60 4l60e c5 c6 aod e4od Torqueflite 727
Originally Posted by www.TCIauto.com
Cooler Fittings
GM Transmission Cooler Fittings
Powerglide - OEM
Fitting Location Thread Size Flow Direction
Upper 1/8" Pipe Return/in
Lower 1/8" Pipe Cooler feed/out
Powerglide - Dedenbear
Upper ¼" Pipe Return/in
Lower ¼" Pipe Cooler feed/out
TH200C Metric, 2004R
Upper ¼" Pipe Cooler feed/out
Lower ¼" Pipe Return/in
TH350, TH250
TH400
700R4/4L60/4L60E/4L65E
4L80E (1991-1996)
4L80E/4L85E (1997 & later)
Rear ¼" Pipe Return/in
Front ¼" Pipe Cooler feed/out
Ford Transmission Cooler Fittings
C3, C4, C5, C6
AOD
AODE/4R70W
E4OD/4R100
Chrysler Transmission Cooler Fittings
All Torqueflite
Front 1/8" Pipe Cooler feed/out
Rear 1/8" Pipe Return/in
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 07:15 AM
What size trans cooler do I need? 84Z Transmission - Rearend 19 11-12-2005 06:18 PM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
air conditioner rad for trans cooler? cboy Transmission - Rearend 15 01-17-2005 02:53 PM
Trans cooler hook-up???'s juveteach Transmission - Rearend 9 09-15-2003 03:23 PM
