trans cooler fittings.. 3/8 hose fitting to a AN fitting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 09:54 AM
scapegoat's Avatar
I have a B&M trans cooler that accepts a 3/8 hose fitting. The type of fitting you would use a rubber hose on with a hose clamp. I am in the process of running steel braided hose from jegs. How do I conect this hose to this cooler. I have the -6AN fittings hooked up to the transmission, I just need to conect it up to the cooler. Is there some type of fitting that converts a 3/8 hose fitting to a AN fitting? I heard there was but I can't find them. Can somebody point me in the right direction? Thanks in advance.
Old 04-14-2008, 11:37 AM
streetrodderbn's Avatar
Certifiable Streetrodder
does the cooler have internal threads,or a hose barb on the ends of the tubes? If it has internal threads, it most likely takes a pipe fitting threaded a/n adapter, that you can purchase from anyone who sells braided lines and fittings, if it has a hose barb type end, your choices are:push the braided hose on and secure with a stainless hose clamp, or trash the cooler, and buy one that takes the internal threaded adapter for the a/n hoses!
Old 04-14-2008, 11:43 AM
malc's Avatar
Born To Be Mild
Do you mean 3/8 hose or 3/8 tube, hardline that is ?
Or do you mean something like this to adapt AN fittings to the cooler ?
Old 04-14-2008, 01:51 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Jeg's sell's a kit to do this.
Old 04-14-2008, 02:33 PM
scapegoat's Avatar
The ends of the cooler look like this, except they are aluminum and are affixed to the cooler permanently. "Part of the cooler" I don't want to have to buy a new cooler.
Old 04-14-2008, 03:05 PM
This is the cooler I use on all my car's.If you can't unscrew your fitting on your cooler.Then I don't think you're going to find what you need.The cooler that I use ,you just need a AN fitting.
Old 04-14-2008, 04:12 PM
scapegoat's Avatar
I got a link here...I think this may be what I need? Im not sure, I woud rather not slide the hose over the end and use a hose clamp. That seems halfa$$ed to do it like that.
http://www.jegs.com/p/JEGS/756885/10002/-1/10019
Transmission (broken) cooler line fitting extraction 78 monte Transmission - Rearend 1 10-21-2007 02:36 AM
Braided fuel hoses all leak gas vapor odor? Steve S Engine 2 04-26-2007 09:52 AM
Banjo fitting illegal?? gavinpierce Hotrodding Basics 10 04-22-2006 10:08 AM
Trans cooler hook-up???'s juveteach Transmission - Rearend 9 09-15-2003 03:23 PM
Trans cooler 302 Z28 Transmission - Rearend 2 07-30-2003 10:33 AM
