Trans cooler fittings - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2005, 09:54 AM
blacklotus's Avatar
Greg
Last journal entry: Wiring begins
I am looking for a several "1/4 male inverted flare to a AN or tube fitting" I am hoping to run stainless steel trans cooling lines on my build up.
Does anybody have any clue as to where to get these. I have tried automotive, home improvement etc.
Thanks
Greg
Old 07-04-2005, 09:56 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
fittings
Try Earl's under the Holley website.
Old 07-04-2005, 10:04 AM
blacklotus's Avatar
Greg
Did that
Tried Earls and didn't see anything but I will try again, also how much pressure are we looking at here?
Old 07-04-2005, 10:41 AM
bracketeer's Avatar
489 Lemans
pressure
About 60 psi. Your garden hose has about 90.
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 07:15 AM
best trans cooler for 50 bucks 1quiknova Transmission - Rearend 3 05-15-2005 10:08 PM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
air conditioner rad for trans cooler? cboy Transmission - Rearend 15 01-17-2005 02:53 PM
Trans cooler hook-up???'s juveteach Transmission - Rearend 9 09-15-2003 03:23 PM
