Trans cooler lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2007, 03:13 PM
JJ350's Avatar
Trans cooler lines
would there be any problems using rubber lines for the cooler lines?
Old 03-07-2007, 03:59 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
No problem. Maybe a leak or two...
Old 03-07-2007, 05:13 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
They make a special rubber line just for transmission coolers. It is made with material that is compatible with the trans fluid. You can get it at NAPA...just tell them that you want the hose that is rated for ATF. Do not use fuel line.
Old 03-07-2007, 05:14 PM
cboy's Avatar
Last journal entry: Finished
What Weirdbeard said with a heavy emphasis on the leaking. I double clamp all my joints and I STILL get leakage from time to time.
Always learning...and sharing what I've learned.
Old 03-07-2007, 05:26 PM
Von MoPar's Avatar
I have been using the correct rubber hose trans lines on my Coupe for 25 years, and I also use them on my Roadster no problems, you can double clam them as suggested.
Old 03-07-2007, 06:06 PM
larryblack's Avatar
Certified Lead Foot
You need to make sure the rubber hose ID is the same dimension as the metal line OD. Tight enough you have to just about force the hose on. If you are going to put a nipple in the tranny, there are ones that are tapered with ridges to "GRIP" the hose inside. These nipples, when properly sized, are leak free and clamping is not always needed.
Too many times the leaks come from too much clearance between the hose and what you are attempting to clamp it to. Then you can NEVER get the clamps to fully tighten down as they distort the hose to out of round. Double clamping on a tight slip fit, AKA minimum clearance helps seal them better.
You can also over tighten the clamps around the hose and actually cause leakage as the seal is compromised.
When you go to the parts store for the ATF compatable hose, ask to see their brass fitting section to find a good compatable metal part to attach the hose to. It comes out neater looking and much cleaner too.
Old 03-07-2007, 06:17 PM
I always run metal lines ... not that hard to do ... and the tools are not that expensive ...
Flaring tools are inexpensive also ...
Good tools do not cost money ... they save money ... but then .....
I never met a tool I did not want to own
Old 03-07-2007, 06:23 PM
larryblack's Avatar
Certified Lead Foot
That is SSSSOOOOOOO true.
Old 03-08-2007, 08:07 AM
Last journal entry: car is painted
You can also use push-loc fittings and not worry about clamps.
Old 03-08-2007, 02:25 PM
coupe66's Avatar
My tranny had rubber-hoses, with double clamps... but not any more, it is a "high pressure" line we are talking about. There was no leak, but they did not look healthy when i removed them.
/Pete
trans cooler tomco550 Transmission - Rearend 1 10-06-2006 03:44 PM
700rd trans cooler 67chevy Transmission - Rearend 1 09-17-2006 07:37 PM
Trans cooler lines which is which atlantis Transmission - Rearend 44 01-08-2006 04:19 PM
best trans cooler for 50 bucks 1quiknova Transmission - Rearend 3 05-15-2005 10:08 PM
Radiator Oil Cooler Lines holes jesse01 Engine 6 04-17-2005 05:38 PM
