Well, you know the liner in the hose is compatible with hot water. The question is, is it compatible with hot transmission fluid?
Haha that's funny you posted this because guess what I just did last weekend, switched up my tranny cooler lines for 2 3/8" dishwasher stainless steel lines I found at rona. I ran it once last weekend with them on there and no leaks and no problems. You should be A ok!!
(my lines cost $25 each and were about 5 feet as well!!)
I have the braided lines on my washer and my toilets too. The only thing I have seen with them is that the braid is not of the same quality as say and Aeroquip or Earls, they have some rust spots on them. Other than that I figure they should work fine for your application.
"What do you guys think?? Will it work OK, or will I be sorry???"
I think you'll be sorry...eventually. As Tech said, there's a difference between hot water and transmission fluid. If it makes you feel any better I'm sure when the core deteriorates and fails it'll be in your driveway on a bright, warm, sunny day |
OK here's my secret trick.
IF you are only interested in replacing the rubber lines that connect the steel to the radiator, and you want pretty braided lines....... Go to your friendly neighborhood airplane shop and get the old lines they take off at mandatory 10 year replacement intervals. These are usually covered with orange heat sleeve that can be easily removed. The AN fittings are 37* but can be attached to the 45* on low pressure lines with no problems.... or you can change the fittings to match the braided 37* lines. Aircraft lines RARELY deteriorate. These lines are extremely expensive new because they are aircraft grade insides with stainless braid..... but FREE if you get them out of the dumpster, or your friendly A&P will save them for you. I know people who use them for fuel lines and brake lines..... but I don't trust them for brakes. Oh, by the way, the heat sleeve is removable, and it sells for $3 a foot in Jegs/Summit,,,, used on spark plug wires to stop melting by your headers. I have about 100 lines saved, from 1/4 inch to 5/8 inch diameter, running from 8" to 36" long. FREE. sssssshhhhhhh, it's a secret |
| trans cooler | tomco550 | Transmission - Rearend | 1 | 10-06-2006 03:44 PM |
| 700rd trans cooler | 67chevy | Transmission - Rearend | 1 | 09-17-2006 07:37 PM |
| Trans cooler lines which is which | atlantis | Transmission - Rearend | 44 | 01-08-2006 04:19 PM |
| best trans cooler for 50 bucks | 1quiknova | Transmission - Rearend | 3 | 05-15-2005 10:08 PM |
| Is it safe to skip the radiator and go strait to the trans cooler? | Ghetto Jet | Transmission - Rearend | 20 | 10-17-2004 09:34 AM |
