I'll try to pay attention a little better from now on.
I took one ( trans cooler) off a Crown Vic police car in the junk yard a few weeks ago, It was on the return line, It being a police car and as hard as they are driven, I would guess thats the best place for them.
Always on the return line. No sense cooling off the fluid and then heating up again with 200 deg water.
line orientation makes no difference...here is another set up to ponder , I run a 3200 ,10.5 stall converter, the trans is plumbed to a large (13000btu) B&M cooler with a total by-pass of the radiator. I am fortunate to have the cooler in front of the radiator, 34's have a nice sloping grill that leaves plenty of room for this. I prefer to isolate the two systems, why? not sure , just seems that useing an external cooler and useing the radiator seems to be an oxymoron, two different heat exchangers doing the same job both having different operating parameters would be some how a conflict.............. different strokes as they say ... ...
Hayden......one of the largest and better known transmssion cooler makers says to run the coolers this way... ![]() That's the way I run mine.....except I have the cooler mounted along the frame rail....not in front of my DEUCE radiator shell....
i put my cooler on after the rad., dropped my engine operating temp 5 degrees. if it dropped the engine temp, its a fair bet thet the trans is running cooler too...
I would disagree. The engine is running cooler because the tranny cooler was blocking air flow to the rad. Now the tranny cooler is picking up heat from the rad causing the tranny to run hotter. Even though the engine is running 5 degrees cooler. The tranny cooler is now picking up 180 degree cooling air from the rad. It was getting 70 degree ambient cooling air from in front of the rad.
"H" - Fitting
I'm also an Alberta resident, and I am back working at a Ford dealership again.
When I worked for Ford in the mid-80's I recall that they were concerned with fluid viscosity in cold climates. Apparently very thick fluid was causing starvation / cavitation (?) precipitating in transmission failures. Thier "fix" was to install an "H" fitting in the cooler lines fairly close to the transmission. If the fluid was too thick, it would take the path of least resistance (thru the middle of the "H") and bypass the cooler altogether. As the fluid warmed to operating temperature (at both ends) it would thin out and flow straight thru the "H" ... again taking the path of least resitance. The theory makes sense to me and I applaud them for coming up with something simple and effective. I'd have to check the part number when I get back to work, but I think the ford basic# is 7G118. (E3TZ-7G118-A?) On second thought ... that basic# is likely 7H322 Last edited by 66GMC; 12-31-2005 at 11:52 AM. |
Seems to me that, after up to operating temp the the path of least resistance may still be across the H, regardless of two 90 degree turns, since the fluid foward of that point that is returning from the cooler is just that; 'cooler', therefore a thicker viscosity. That would mean the thinner fluid leaving the tranny would create a condition of a greater percentage of the hot fluid bieng returned back to the tranny {uncooled}. Also there is the factor of a much less distance accross the H and not needing to overcome resistance created via pumping through the flews of the cooler. I could see it being a good idea if there was a manual thermal check valve in the cross feed line that was normally open per colder temp. I don't foresee needing to make a modification like that here in Mississippi, but I can see where it would be an excellent system to help prevent thick fluid cavitation problems up there where you guys see some really cold temps. If you can, when you check on that #7H322, see if you can find a schematic to look at to make sure they did not install a check valve in the cross-feed line. Thanks for some valuable info 66GMC. ![]() EDIT: BTW; I see YOUR PASSENGER listens well, "Get in, sit down, hang on". LOL
Well, I've done a little more research from home on this.
http://www.fahringer.net/x/4r100disasm.htm Have a look at item #122. It appears that the technology may have changed SLIGHTLY on this, but I'm fairly convinced that 7H322 is the right "basic" number... Ford now calls this a "CBV" (Ford has acronyms for everything )CBV = Coolant Bypass "Valve" ... which implies what you are thinking about. It appears to be a tube attached directly to the transmission case, and mounted using banjo fittings. The old "H" fitting that I mentioned previously sure didn't look like it had any type of check-valve or restrictor at all, but I may be wrong in assuming that. I couldn't find anything on my Ford (Dealer Only) website, but this TSB may be relevant and contain the part number if you can dig it up somewhere. Quote:
And yeah ... the "Hang On" picture in my Avatar is priceless. A friend had sent me an e-mail entitled "You know you're driving too fast when..." followed by the pic. I sent a request to Jon to use it as my Avatar. Don |
| Trans. cooler lines | Novaman78 | Transmission - Rearend | 12 | 10-08-2006 07:15 AM |
| Can I use a trans cooler only without a radiator cooler? | supercab78 | Transmission - Rearend | 5 | 04-14-2005 01:46 PM |
| air conditioner rad for trans cooler? | cboy | Transmission - Rearend | 15 | 01-17-2005 02:53 PM |
| Trans cooler lines with headers | sledge57 | Transmission - Rearend | 2 | 11-23-2003 12:51 PM |
| Trans cooler hook-up???'s | juveteach | Transmission - Rearend | 9 | 09-15-2003 03:23 PM |
