Trans Cooling Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2006, 08:52 PM
MI2600's Avatar
Member# 3287
Trans Cooling Lines
I just got the 200R4 into the '72 El Camino. The cooling lines are reachable, but I don't have as much room as I'd like. I need to have a fairly sharp bend coming off the upper line on the trans. I've already mangle one steel line. I failed Line Bending 101 in college.
Anyway, is it permissible to use aluminum line rather than steel? It's so much easier to work with.
Old 08-11-2006, 09:36 PM
I wouldn't use aluminum. What tool are you using to bend the line?
Old 08-11-2006, 09:41 PM
MI2600's Avatar
Member# 3287
I've got one of those plier types.
Old 08-12-2006, 05:53 AM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Why don't you use braided hose with AN fittings?
Old 08-12-2006, 07:53 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I used steel brake lines and bent them to what I needed. Granted, it was easy with the motor and tranny sitting on stands. The bender used was a cheap model from Harbor Freight.
The lines have what seem to be some funny bends, but I mocked things up with the headers and other items installed. Braided hose and fittings would be a very good choice as well.
ID:	14074   Click image for larger version
Old 08-12-2006, 08:28 AM
I put a lot of lines on ... fuel, brake, transmission ECT so I have a good selection of benders and tubing flaring tools.
Good tools do not cost money ... they save time and money $$$
Go to a industrial supply house and get a Imperial tubing bender ... the bad thing is the tool only works for 1 size tubing ... you need one for each size ...
Deuce ...
Old 08-12-2006, 05:32 PM
MI2600's Avatar
Member# 3287
Thanks for the ideas and support.
I've kind of shied away from bending because of disastrous results I had a long time ago with stainless. I've been playing with the lines and noticed that it helps me a little if I connect one end rather than trying to eyeball, remove the line, bend and test fit.
If you're not doing anything next Saturday and want to help, I'll be home.
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 07:15 AM
Which line is which on a powerglide trans? tm454 Transmission - Rearend 3 12-07-2004 07:21 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 11:50 PM
Manual trans cooling scott011422 Transmission - Rearend 7 07-07-2003 10:25 AM
